I recintly replaced the whole councle and radio housing and when putting back newer parts, I'm hookin the lighter up and it keeps popping the fuse over and over. I have the car running while doing this as I read before and even tryed numerous lighting housing's. I've never done electrical work before but am reading up on it and was thinking of clipping the wire's at the lighter connector tips to the fuse box and securing the wiring myself because there's no way I'm confident in tearing up the whole roll, because I assume the wire is hitting something so I was told. And I'm not even sure if the wire's connected directly to the fuse box. That being said, thank you for your time, and sorry about the penmanship.
Mar 7, 2009 at 10:54 AM
