1985 Pontiac Firebird Brakes grinding
1985 PONTIAC FIREBIRD
103,000 MILES • 6 CYL • 2WD • AUTOMATIC
SLAMPUNK05
Alright i bought an 85 firebird and the breaks were shaky so i went ahead and changed the brakes and rotors. The change was very easy as far as that goes. But now i am getting a really bad grinding we checked the wheel baerings and that wasnt the issue. It seems the grinding is comeing from the brake pads. We thought they just needed to be worn down, yet the ginding will not stop the brakes grind while moving and squeak when turning. i was just looking for anyone who may have any suggestions. allright thanks for your help.
Jan 7, 2008 at 11:59 AM
  • 31,937 POSTS
Hi there,
you better check that the pads are installed the correct way, as some pads are L & R handed (in the calliper) make sure that they are the correct pad for your car and that all brake components are fitted correctly and are secure.
Mark (mhpautos)
Jan 7, 2008 at 12:25 PM
