When the blinker switch is turned to either side it won't make the clicking sound it should.
Jan 20, 2008 at 2:35 PM
MIKE H R
MEMBER
do the blinkers work at all? if not then i would change the flasher.
Jan 21, 2008 at 12:26 AM
SETACONE
MEMBER
The blinkers work fine. The clicking sound is the only thing that won't work.
Jan 21, 2008 at 2:21 PM
MIKE H R
MEMBER
some flashers have a distintive clicking sound when working and some don't, the flasher should be in a clip that holds it under the dash. that clip carries the sound of the flasher working so it is heard.
