1984 Pontiac Firebird timing chain setup
1984 PONTIAC FIREBIRD
WAXANDGO
  • 23 POSTS
Engine Mechanical problem
1984 Pontiac Firebird V8 Two Wheel Drive Automatic 184K miles
i disconnected the timing chain and rotated only the crank (lost count maybe 2 or 3 times). now the two dots on the cam and crank meet at 6 & 12 o'clock, respectively. the number 6 piston seems to near the top but not sure (nor do i think it is TDC). the striker on the rotor is just past the number three (following the firing order). what do i move to get the striker on the number six? will i cause any damage to the push rods (or anything else) if i connect the battery to turn the engine? what is the best way to turn the crank? now i have all the spark plugs out.
Mar 28, 2009 at 6:32 AM
DOCFIXIT
  • 18,828 POSTS
With crank at 12 and cam at 6 then it times off cyl 6 so rotor needs to be pointing at wire for cyl 6. Remove dist and reset turn engine by hand NO STARTER put crank bolt in and turn with that
Mar 28, 2009 at 7:05 AM
WAXANDGO
  • 23 POSTS
is it automatically set up that if crank at 12 and cam at 6 removing the distributor and resetting it at the # 6 Wire will put me in time? and I can close it up and drive away?
[quote:c8d8c54013="Docfixit"]With crank at 12 and cam at 6 then it times off cyl 6 so rotor needs to be pointing at wire for cyl 6. Remove dist and reset turn engine by hand NO STARTER put crank bolt in and turn with that[/quote:c8d8c54013]
Apr 2, 2009 at 12:52 AM
DOCFIXIT
  • 18,828 POSTS
Yes light it up
Apr 2, 2009 at 8:14 AM
