1984 Pontiac Firebird steering column wiring
CFD2315
Electrical problem
I am installing a gm column in my wifes vw dune buggy
i need to know which wires are which on the connection that is on the column. i will attempt to use the factory wiper control and the ignition as well as the horn. i am unsure if it has a delay or not on the wipers if i can get it hooked up for low and high i am okay with that.
Apr 22, 2010 at 1:26 PM
HMAC300
  • 48,601 POSTS
your best bet is to get a manual from an 84-5 car you took the column from. try a library or something similar to that. there is part of the switch for the delay but most of it is done in the circuit board for the motor itself.
Apr 24, 2010 at 8:14 AM
