1984 Pontiac Firebird Shifter cables
1984 PONTIAC FIREBIRD
167,000 MILES • V8 • 2WD • AUTOMATIC
BUNDY140
Just looking for some general info. My 1984 Pontiac TransAm has an auto trans. At the bottom of the shifter lever are two cables. I know one cable is the shift cable that runs directly to the transmission. What is the other cable and what is the other end conected to.
Aug 7, 2009 at 6:27 AM
HMAC300
  • 48,601 POSTS
it may go to your brake pedal or steering column so you can't shift ou t of parkunless you depress the brake or turn the key on...
Oct 9, 2009 at 1:35 PM
