1983 Pontiac Firebird Help with engine removal
1983 PONTIAC FIREBIRD
90,000 MILES • V8 • 2WD • AUTOMATIC
SFLTHNDRCHKN
I have remove everything I have read and know to remove the 305 from my firebird. Even after removing the 'through bolts' on the motor mounts, the engine will not seperaqte from the frame. I was attempting to pull engine and trans as one move. Cannot find why motor will not lift. Please help
Mar 12, 2010 at 2:51 PM
ERNEST CLARK
  • 1,730 POSTS
Did you remove the rear transmission mount??? If so, then you need to look for the engine or one of it's parts getting caught on something.
Mar 18, 2010 at 2:22 PM
