You can put a cam up to.500" with no problems. By the way the valve will hit the piston, not the cylinder wall. But if it does it will cause extreme damage. That lift will also include the rocker arm ratio. Take the advertised cam lift and multiply by 1.5 and that will give you the total lift in the cylinder.
SPONSORED LINKS
Monday, September 14th, 2009 AT 5:38 PM
