1981 Pontiac Firebird delay in rear end engagment
1981 PONTIAC FIREBIRD
SORDOFCONAN
Drive Train Axles Bearings problem
1981 Pontiac Firebird V8 Two Wheel Drive Automatic
after having the transmission rebuilt by a local very good mechanic for a broken orbital gear and replacing both u-joints my car still has a 1 second delay after you shift from either P or N with a clunk as the rear engages, i have to replace a axel shaft seal so while i have it apart what should i look for to cure this dilemma, the auto parts guy says i need to adjust the pinion, not sure what he means, with shims? the tranny is a 350. thank you for any help
Jul 29, 2009 at 8:12 AM
  • 31,937 POSTS
HI there,
what he is talking about is the pinion back lash, not this is a critical setting if you get it wrong you will destroy the diff, i would get a mechanic to set this up for you.
mark (mhpautos)
Jul 29, 2009 at 4:39 PM
