1980 Pontiac Firebird Dash panel
1980 PONTIAC FIREBIRD
GHURTA
Interior problem
1980 Pontiac Firebird V8 Two Wheel Drive Automatic
I am looking for replacement lens for the turn signals in the dash insert. These lens are a thin green plastic with arrows on them. They fit on the backside of the gold turned dash insert (round indicators). This is for a special edition turbo trans am. Is there an aftermarket replacement for these?
Feb 25, 2009 at 7:53 AM
MIKE H R
  • 3,094 POSTS
You can check with e-bay to see if anyone has the indicators or you can go on the web site, yearone.com They handle after market parts for most older fords and pontiacs. If you don't see what you need on line you can call up and explain what you need and they might be able to help. Other than that all I can say is that you
Mar 9, 2009 at 4:05 AM
