1979 Pontiac Firebird steering column
88,500 MILES • V8 • 2WD • AUTOMATIC
JAYSS403
I was wondering is I could get a walkthrough or repair instrutin for putting back/replacing turn signal switch or from the tun signal switch back up.
Aug 15, 2008 at 8:52 AM
KEVIN12881
  • 336 POSTS
You should get a haynes book. This procedure is not that hard, but has to be done in a certian order. I just did mine (although newer) and it had several lock washers that had to be put in in a certain order. Did someone mark the center bolt with the nut for the correct position? I think it is lock washer, the spring that needs put in with a compressor, lock washer, roller washer, nut and then steering wheel
Sep 5, 2008 at 11:55 AM
