1977 Pontiac Firebird Transmission change
100,000 MILES • V8 • 2WD • AUTOMATIC
MDSMITHRD
I currently have a 1977 Pontiac Trans Am, 400 ci V8, with three speed auto and want to change to a four-speed manual shift which was an option for my auto from factory. What is the process and is this a hard and laborious process? Thanks!
Jul 25, 2008 at 2:16 AM
DOCFIXIT
  • 18,828 POSTS
It can be done and yes it will be laborious. I have no idea where you would find a how to search the net outfit called Year One maybe helpful.
And pack a lunch
Good luck
To do
Clutch pedeal and all linkage to trans
shifter mounting
flywheel
bell housing and trans
crossmember
drive shaft
Jul 25, 2008 at 2:50 AM
