Check the ignition timing, also could be wrong heat range of spark plugs, lean or rich mix, hot valves and carbon in the chamber. Also check the carb's accelerator pump. When you pull the throttle back you should see a stream of fuel out of the Acc, Pump-
Also check the fuel pressure-
SPONSORED LINKS
Tuesday, June 3rd, 2008 AT 3:09 AM
