1967 Pontiac Firebird oil leak
BIRD326
Engine Mechanical problem
1967 Pontiac Firebird V8 Two Wheel Drive Automatic
im noticing minor oil leaking from the valve cover breather whats causing this
May 12, 2008 at 8:48 AM
MIKE H R
  • 3,094 POSTS
check the brather cap to make sure it is clean and also check the pvc valve. When engines run they can build up some pressure inside the crancase. if the pvc is dirty and cap it would tend to put more pressure making it leak. you might want to think about getting a compreesion check done, eliminating the thought of it being the rings. What it sounds like is that the breather cap and pvc valve need looking at. Quick check on pvc is by taking the valve ansd shaking it. you should be able to hear the little valve rattle when shacking it.
May 13, 2008 at 3:27 AM
