rough idle
DINO22
I have a 1985 Fiero with the 2.5L. At engine temp. the RPMs vary from about 500 to about 1500. It willl idle at about 1500 for a couple of seconds then drop to 500 for a few seconds then back up to 1500 for a couple seconds and back down to 500. It does this repeatedly. It also so makes a chugging sound out of the tail pipe. There is some white smoke comming out of the tail pipe too. But the oil on the dipstick looks good. The exhaust smells strong, I think that the engine is running REALLY rich. There is 160,000 mile on the engine. No trouble codes to report. What should I look for?
Apr 14, 2007 at 5:05 AM
VBELEN4
WHat about replacing the oxygen sensors?
Apr 18, 2007 at 8:40 AM
DINO22
I don't think that is it. I checked trouble codes and originally found that the o2 sensor had come apart. But after reconnecting it problem continued. But I did find that by unpluggung the vacuum line from the MAP sensor my idle problem has stopped. I think I just need a new map sensor.
Apr 19, 2007 at 12:13 AM
