1988 Pontiac Fiero Shift Cables
38,000 MILES • 6 CYL • 2WD • MANUAL
LARRY HILMOE
I have replaced the 5 spd Getrag and still cant shift the transmission from the drivers seat. I have ordered a new selector and shifter cable along with a transmission mounting bracket. Now I find info that there are bushings and bearings that might need replacing.. Is this true? (and where are they located, on the shifter lever?
Thanks,
Larry
Feb 4, 2009 at 7:20 AM
MMPRINCE4000
  • 8,548 POSTS
The bearings and bushings are in the shifter housing in the console. Replacement bushings, cables and brackets are available from rodneydickman.com.
Feb 10, 2009 at 10:41 PM
