Engine Mechanical problem
1988 Pontiac Fiero 6 cyl Two Wheel Drive
What is the current correct procedure for setting valve lash on a GM 2.8L / 3.1L V6 ?
I understand the procedure in the service manual and the Haynes manual has been updated to a new procedure. An engine is being built (all new), and the valve lash will be set (static set) with or without oil in the lifters, depending upon the "correct procedure.
Thank you
Thank you
Mar 2, 2010 at 3:12 AM
