1986 Pontiac Fiero Turn Signal Issue
1986 PONTIAC FIERO
107,000 MILES • 6 CYL • 2WD • MANUAL
HNC_DELTA
Hi... When I use either left or right turn signal the battery gauge moves in synchronization. Can this be a bad ground?... and if so where should I look first to fix the issue?
Thanks!
Apr 2, 2008 at 11:34 AM
HNC_DELTA
Any ideas anybody?
Apr 3, 2008 at 3:18 AM
2CARPRO JACK
  • 11,533 POSTS
Doubt if there is a problem. Sometimes the gauge has th esame power source as the t-signals, and will show the fluctuation on the gauge, wouldnt worry about it
Apr 4, 2008 at 12:35 AM
HNC_DELTA
Thanks for the reply... I thought of that also, but it seems them particular gauges and turn-signals have their own fuses. So I thought a bad ground may have been creating it some how or the volt gauge is going out.
Apr 6, 2008 at 4:10 AM
2CARPRO JACK
  • 11,533 POSTS
Own fuses but power origin is the same
Apr 7, 2008 at 12:24 AM
