1986 Pontiac Fiero The transmission will not shift
1986 PONTIAC FIERO
49,806 MILES • 6 CYL • 2WD • MANUAL
RUMMYARIA
Is the transmission shifter accessible without removing the transmission? Can I check the shift forks easily?
Dec 30, 2008 at 9:55 AM
MMPRINCE4000
  • 8,548 POSTS
You can remove the cables without removing the trans.
There are two cables, shift and select. The cables may be loose, bracket loose/cracked. The shifter bracket in the cabin may be loose, or the clutch arm/slave cylinder may be bad.
Go to fierostore.com for replacement parts.
Jan 30, 2009 at 12:54 AM
MMPRINCE4000
  • 8,548 POSTS
Also check TV cable.
Jun 20, 2009 at 1:23 AM
MMPRINCE4000
  • 8,548 POSTS
TV cable bolts to top of trans and winds around to throttle body cam.
Jun 21, 2009 at 2:03 AM
