1986 Pontiac Fiero TEMP GAUGE
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
SEASIDESEAHORSE
I have a problem with the Temp Sensor. I have replaced the temp sender but the tempature guage immediately goes past the red. The engine is not hot and the Temp light does not come on. I get a code 15
when checking the codes. The fan DOES go on when I turn on the A/C. Help!!!
Aug 18, 2010 at 12:26 PM
  • 75,988 POSTS
How about about the coolant temperature sensor also did you test the wires?
Aug 18, 2010 at 1:11 PM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1986_pontiac_fiero_code_15_part1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/416332_1986_pontiac_fiero_code_15_part2_1.jpg
Code 15 is for high signal voltage in the coolant temp sensor circuit.You most likely have a open from the sensor to the ecm.I posted a wire diagram and what the cause for that code is.Let me know what you find.
Aug 18, 2010 at 1:15 PM
