I NEED INFORMATION ON RECALLS FOR THIS VEH. GM SAID THEY CANT FIND ANY. IF THEIR ARE ANY I NEED THE RECALL NUMBER FOR IT.
Oct 8, 2008 at 5:51 AM
MMPRINCE4000
✓Experienced Mechanic
There were a couple I can think of. One to remove the weatherstripping from the rear decklid (under back window). Rerouting the air intake hoses, and adding a stamped steel plate to the firewall exhaust manifold. This plate was supposed to prevent a fire if a rod made its way through the side of the block.
This never worked and is a guarenteed exhaust leak if it is done.
Oct 16, 2008 at 1:43 AM
