1986 Pontiac Fiero instrument panel
GALVAN
Electrical problem
1986 Pontiac Fiero 6 cyl Two Wheel Drive Manual 155xxx miles
i have checked all the wires and plugs to my speedometer and all check out fine however the speedometer or shift light does not work. rpms show and everything else. when i tap on top of the dash the speedometer needle jumps but the rmp stay still... any ideas how to get my speedometer working...? or where i can find a new one for it?
Mar 5, 2009 at 4:05 AM
MMPRINCE4000
  • 8,548 POSTS
Go to fierostore.com and see if they have a replacement. The IP uses a mylar "circuit board" and they will deterorate over time, you can remove IP and try to clean it.
Mar 13, 2009 at 1:04 AM
