1986 Pontiac Fiero car doesn't crank
1986 PONTIAC FIERO
178,000 MILES • 4 CYL • 2WD • AUTOMATIC
BAILIE
I cant figure this out. Sometimes when I shut my car off, then return to get in and go, it doesn't crank. It makes no noise at all. If I continue to try and crank it it still doesnt crank. HOWEVER, if i leave it alone for several minutes without trying then it will crank. It doesnt do this all the time. it does it when I least expect it. Ive already had the starter redone, checked battery cables.... I'm lost on this one. Any clue or suggestions of the problem?
Apr 28, 2008 at 10:15 AM
MASTERTECHTIM
  • 4,750 POSTS
try starting it in neutral, maybe your neutral safety switch is no good.
Apr 28, 2008 at 10:18 AM
BAILIE
i tried that, i tried everything i could think of. Someone said I may have a ground problem.....?
Apr 28, 2008 at 10:57 AM
MASTERTECHTIM
  • 4,750 POSTS
well you need tyo make sure the battery terminals are tight and also check with a test light to see if the starter is getting powser when you are trying to start it.
Apr 28, 2008 at 11:00 AM
BAILIE
ok, thanks. Haven't tried that.
Apr 30, 2008 at 3:10 AM
