When turning the key to the "Start" position the engine will not crank. Battery is good and the guages work in the "On" position. Also, with headlights ON and turning the key to "Start" the lights do not dim. No sound of the starter engaging.
This happened before when the steering wheel was in the "UP" position and I lowered the steering wheel and the engine cranked and started.
Any suggestions as to cause of this problem?
Oct 3, 2007 at 11:22 AM
