Notes: The fiero itself has about 225,000 miles, the engine was replaced with a new jasper about 12,000 miles ago. Everything else (barring expendable parts like breaks) is original.
My Fiero has been grinding a bit when going into 4th gear for quite some time, about a month ago, it also began to have trouble getting into 1st gear unless I was completely stopped, put it in 2nd, then go to 1st.
2 days ago, 4th gear went out entirely. God-awful noise, followed by no 4th gear (1st, 2nd, 3rd and reverse work fine).
So, I'm guessing I need to replace the transmission (if anyone has another issue that might be an easier fix, please let me know)...
I know it is possible to swap out the transmission without taking out the engine entirely, however, you need some sort of support system for the engine. I found instructions on fabricating such a system once upon a time, but now I can't seem to find anything of the sort.
Does anyone know where I might find instructions to fabricate such a support system?
Thanks
Thanks
May 2, 2008 at 8:10 PM
