1985 Pontiac Fiero TIMING
PINK1
Engine Performance problem
1985 Pontiac Fiero 6 cyl Two Wheel Drive Automatic
NEED TO FIND OUT IF YOU CAN TIME A 2.8 WITHOUT A TIMING PLATE. PLEASE TELL ME HOW.
Aug 20, 2008 at 2:48 PM
MMPRINCE4000
  • 8,548 POSTS
Ground terminals A and B of the ALDL (located behind the plate in the front of the console). Check timing with an inductive timing light on #1 wire. Timing should be 10 degrees BTDC.
Aug 24, 2008 at 9:56 PM
