1985 pontiac fiero SE
1985 PONTIAC FIERO
MX~MASTER
  • 27 POSTS
My car will only fire in 3 cylinders and will only start by priming it. And when it is running and i floor the gas it doesn't go above 1000 rpm. I am thinking it something might be wrong with the intake valves.
Jul 24, 2006 at 9:04 AM
MIKEYBDMAN
  • 623 POSTS
Have you checked to see if you are getting good fuel pressure?
Do a compression check on all of your cylinders to eliminate intake vavles.
Jul 24, 2006 at 10:11 AM
MX~MASTER
  • 27 POSTS
i just replaced the intake manifold off another feiro i had and it didn't do much...how would i check the compressison
Jul 24, 2006 at 2:35 PM
MIKEYBDMAN
  • 623 POSTS
[quote:b57405fa2e="mx~master"]i just replaced the intake manifold off another feiro i had and it didn't do much...how would i check the compressison[/quote:b57405fa2e]
You will need to either buy or borrow a compression gauge. Remove all of your sprak plugs, and you will need to disable the ignition circuit. Screw the compression gauge and hose into the spark plug hole of the first cylinder. Have someone turn the engine over about 3 revolutions and you will see the pressure build and stabalize. I would think you should get atleast 120 psi or more on each cylinder. But most likely if you have one bad cylinder, it will be alot lower than the others.
Jul 25, 2006 at 8:02 AM
MX~MASTER
  • 27 POSTS
[quote:9d11bd49fc="Mikeybdman"][quote:9d11bd49fc="mx~master"]i just replaced the intake manifold off another feiro i had and it didn't do much...how would i check the compressison[/quote:9d11bd49fc]
You will need to either buy or borrow a compression gauge. Remove all of your sprak plugs, and you will need to disable the ignition circuit. Screw the compression gauge and hose into the spark plug hole of the first cylinder. Have someone turn the engine over about 3 revolutions and you will see the pressure build and stabalize. I would think you should get atleast 120 psi or more on each cylinder. But most likely if you have one bad cylinder, it will be alot lower than the others.[/quote:9d11bd49fc]
I checked my compression but it still is good enough that it should all be firing :?
Jul 25, 2006 at 6:02 PM
MIKEYBDMAN
  • 623 POSTS
Have you checked to see if that spark plug is firing? You need to check for aprk at that plug. Look for a bad apark plug wire, or bad spark plug. Could be not getting enuff fuel pressure to run smooth also. I would check your plaugs and your fuel pressure. If you are getting good fuel, good spark, then that leaves timing.
In re-reading your original post, you fuel pump may not be pumping properly. I would check fuel pressure next. This is how the manual describes a fuel pressure check.
FUEL SYSTEM PRESSURE RELEASE
4 & 8 Cylinder Engines
With engine Off, remove fuel pump fuse from fuse block.
Start engine and allow to run until fuel supply is exhausted.
Crank engine an additional 3 seconds to ensure fuel supply is exhausted.
Install fuel pump fuse.
On 4-112 and 4-121 overhead valve engines, install fuel pressure gauge between throttle body side of fuel filter at the rear of the car. On 4-151 engines, install fuel pressure gauge between TBI unit and steel fuel line. On V8 engines, install fuel gauge between front and rear TBI units steel fuel line.
Start engine and observe fuel pressure. It should be 9 to 13 psi.
Relieve fuel system pressure. Refer to steps 1 through 3 above.
Remove fuel pressure gauge and reinstall fuel lines.
Start engine and check for fuel leaks.
FUEL SYSTEM PRESSURE TESTING
Before servicing fuel system components, fuel system pressure must be released. To relieve pressure, proceed as follows:
Remove fuel pump fuse from fuse block.
Run engine until fuel remaining in lines is consumed. When engine shuts down, engage starter for approximately three seconds to relieve any remaining pressure.
With ignition off, replace fuel pump fuse.
Remove air cleaner and plug THERMAC vacuum port on throttle body unit.
Remove fuel line between TBI unit and fuel filter or between front and rear TBI units on ``Crossfire'' injection systems. Use a suitable back-up wrench to hold flare nut on throttle body when removing line.
Install fuel pressure gauge J-29658 or equivalent, between throttle body and filter or, on ``Crossfire'' systems, between front and rear TBI units.
Check pressure reading with engine running. If fuel pressure is not between 9 and 13 psi, refer to ``Fuel System Diagnosis.''
De-pressurize fuel system, remove pressure gauge and reinstall fuel line.
Remove plug from THERMAC vacuum port and install air cleaner.
Jul 28, 2006 at 7:39 AM
MX~MASTER
  • 27 POSTS
I tested the compression and its good enough still that they should all be firing and there is spark. I changed the fuel injectores and it seemed to get worse now its only firing in one cylinder and backfires
Jul 29, 2006 at 8:40 AM
MIKEYBDMAN
  • 623 POSTS
[quote:d78a2b9640="mx~master"]I tested the compression and its good enough still that they should all be firing and there is spark. I changed the fuel injectores and it seemed to get worse now its only firing in one cylinder and backfires[/quote:d78a2b9640]
I would check the fuel pressure. I posted instructions on how in an earlier post.
Jul 29, 2006 at 9:03 AM
MX~MASTER
  • 27 POSTS
i checked the fuel line pressure and its alright could it be the timing or the computer?
Sep 4, 2006 at 9:14 AM
MX~MASTER
  • 27 POSTS
anyone with any other ideas????
Sep 20, 2006 at 2:46 PM
MX~MASTER
  • 27 POSTS
I got the problem fixed it was the book the firing order they have wrong in the book so we changed the spark plug wiring different but its still not firing in one cylinder do u think it could be a dead injector?
Apr 4, 2007 at 4:17 PM
MCFERRANCE
  • 100 POSTS
Have you thoroughly checked the ignition system?
Is this a 4 cylinder?
I believe that this has a distributor cap. Do you have spark at each cylinder? Have you replaced the cap and rotor? Have you checked and/or changed the plug wires and plugs?
Another thing to do is to unplug the wire connection at the distributor and check and clean them, and also spread the male terminals to get better contact. I had a problem with this connection that was corrected by doing this.
You may need to check the ignition timing also.
If this is a 4 cylinder it has a TBI and 1 injector, correct?
If this is a 4 cylinder, it is unlikely that the camshaft and crankshaft jumped time and would still run. If it is a 6 cylinder it could jump time and still run, although not very well.
Apr 6, 2007 at 7:49 AM
MX~MASTER
  • 27 POSTS
yeah it is a v6 and it is running just not on all cylinders, and we got the plugs down to one injector so if we change the 6th injector it should be good
Apr 6, 2007 at 8:24 AM
MCFERRANCE
  • 100 POSTS
Isn't this a 2.8L with a TBI and 2 injectors? Does this have a distributor?
The more specifics we have about the engine size, ignition, injectors and such, the easier it will be to help you.
Apr 6, 2007 at 9:39 AM
MX~MASTER
  • 27 POSTS
yes its a 2.8L and it has a distrubtor and 6 injectors
Apr 6, 2007 at 1:32 PM
MCFERRANCE
  • 100 POSTS
Let us know if the injector takes care of it.
Apr 6, 2007 at 11:45 PM
MX~MASTER
  • 27 POSTS
Its still not running on one cylinder
Apr 12, 2007 at 3:32 PM
MCFERRANCE
  • 100 POSTS
Are you sure that you have good spark at each cylinder.
If you are sure that it is the injector, the next thing to check would be the wiring to that injector and then next would be the computer.
There are "noid lights" available to insert between the injector and the wiring plug to see if it is getting its electrical impulse from the computer. This should be available for your application. They should be available through a parts store or tool dealers such as Snap-on, Matco, or Mac.
Apr 13, 2007 at 2:47 AM
MX~MASTER
  • 27 POSTS
I have gotten it to run in all 6 cylinders now, but my idle is way to high and my engine is overheating. I tried pluging an open vacume hose and it idled it down to where it should be, but when i attatched the vacume line to the intake manifold where it should be it, the idle went way back up like before, i am clueless on what i should do.??
Oct 23, 2007 at 4:38 PM
MCFERRANCE
  • 100 POSTS
What does this vacuum line go to?
It sounds like the vacuum line is leaking from a tear, crack, or hole in it; that it isn't hooked up to what it controls, or the part that it controls is faulty and leaking.
One other thing would be to check if the vacuum lines are ALL hooked up correctly. Especially check the parts that have 2 vacuum lines on them to make sure they aren't hooked up backwards. Some applications have check valves in line. if these are backwards, it would cause a vacuum leak such as you describe.
Oct 24, 2007 at 2:50 AM
MX~MASTER
  • 27 POSTS
The hose goes from the underneath carburator to the intake manifold, its a pretty big line, and to me it seems like its the only place to go because of a metal hose which doesn't allow bending to anywhere else the peice fits there, and i cant find any other lines for those two to go other than that. And when the one hose coming from the bottom of the carburator is not pluged the check engine light is on.
Oct 26, 2007 at 4:24 AM
MCFERRANCE
  • 100 POSTS
A large hose would either be for the PCV valve in the valve cover or the power brake booster. No matter what, if it doesn't go to anything, then it would be capped off.
Do you have a vacuum diagram on the car somewher to help you figure this out?
Oct 26, 2007 at 4:40 AM
MX~MASTER
  • 27 POSTS
I know its not the PCV because of the vacume diagram but everything else is hard to tell what is what on the diagram. Is there any site that has a vacume diagram of fieros?
Oct 27, 2007 at 5:05 AM
MCFERRANCE
  • 100 POSTS
I have a vacuum diagram in my Chilton Fiero manual. It looks like the only other large line on it goes to the charcoal canister for emission control.
I can fax this diagram to you if you give me a fax number.
Nov 10, 2007 at 10:11 AM
MX~MASTER
  • 27 POSTS
I changed the computer and it seemed to fix the idle but there is still a hissing sound i just need to find the small leak and i still have to time it does anyone have any instructions on how to do that?
Nov 12, 2007 at 4:03 PM
MCFERRANCE
  • 100 POSTS
My manual says to see the underhood sticker for timing spec. If you don't have the sticker, it is most likely 10 degrees BTDC.
The manual says to hook the timing light up to cylinder #1 plug wire.
Then disconnect the 4 terminal connector at the distributor.
Start the engine and run at idle speed.
Then aim the timing light at the marks on the harmonic balancer/timing gear cover.
If necessary, loosen the distributor clamp and turn the distributor to adjust the timing. When it is set, tighten the clamp and recheck the timing marks.
Shut off the engine, then reconnect the 4 terminal connector.
Before doing this, I always use white chalk, touch-up paint, or crayon to mark the timing marks. It makes it a lot easier to see them with the timing light.
Nov 13, 2007 at 9:34 AM
