my car was fine up until a few minutes ago where the coolant goes started making funny noises and then the coolant started to over flow the dummy light for the temp came on i dont think the temp gauge works it has never moved past 100. it does not have a leak its just over flowing i cant tell if the thermostat is good or bad because the temp gauage doesnt work i will check it as soon as i find out where it is but i would like to know if it is possibly a different problem frst (im thinking the cooling system is clogged)
May 13, 2010 at 1:25 PM
