1985 Pontiac Fiero clutch will not shift in run
1985 PONTIAC FIERO
71,000 MILES • 6 CYL • 2WD • MANUAL
JOHNFIERO
I cannot get the clutch to engage. The pedal doesn't seem to travel as far as before. Master cylinder has been replaced. Is this possible a slave clutch problem. How, do you get access to the slave mounting bolts.
Sep 8, 2009 at 12:06 PM
MMPRINCE4000
  • 8,548 POSTS
the slave is directly under the throttlebody, two 13mm bolts hold it. Remove air tube to TB.
Try bleeding first, and look for any leaks at line connection.
Oct 10, 2009 at 1:59 AM
