1984 Pontiac Fiero New Electric Fuel Pump not working
1984 PONTIAC FIERO
129,000 MILES • 4 CYL • 2WD • AUTOMATIC
DAVIDP
Just replaced and electric fuel pump ...
I can hear pump working for 2 seconds to prime the line whenever I turn the key on and when cranking engine ...
No fuel being pumped out ...
Checked at fuel filter and injectors ...
**Car had been sitting for some time with stale gas **
Tank drained and cleaned out with fresh gas added when installing new pump
Aug 10, 2008 at 7:34 AM
TRADE214
I had the same symptoms. It turned out that I had missed a crack in the flex hosing that connected the new fuel pump to the fuel feed line (yes, inside the gas tank). Once I replaced the hose I had no more problems with fuel feed from the pump.
Aug 23, 2008 at 9:50 AM
