1984 Pontiac Fiero
1984 PONTIAC FIERO
BRM
Electrical problem
1984 Pontiac Fiero 4 cyl Two Wheel Drive Automatic
my brake lights dont work i replaced brake light switch the two right turn stop,light stop relays and all bulbs i have power coming out of the brake light switch plug but no power to the relays or to the back of car fuse is good i have blinkers , tail lights ,turn signals but no brake lights is there anything esle that i can check are anything that would stop them from working.
May 5, 2009 at 7:59 PM
HMAC300
  • 48,601 POSTS
check to see if you got power ging to the turn signal switch then back out. Alot of times this is the problem.
Oct 24, 2009 at 6:46 PM
