My car has an indoor pool!!!
PONTIAC BONNEVILLE
APPLESAUCE
  • 5 POSTS
im getting water accumulation on the back passenger floor! its not the door seals, i checked that with a hose. someone said it had something to do with the condenser. is it plausible to fix this myself?
Oct 21, 2007 at 8:00 AM
I don't recommend your part on it-It needs an AC tech to fix it.
Oct 21, 2007 at 8:32 AM
APPLESAUCE
  • 5 POSTS
[quote:7bebef5cc7="rasmataz"]I don't recommend your part on it-It needs an AC tech to fix it.[/quote:7bebef5cc7]
any idea what it might be???
Oct 21, 2007 at 9:40 AM
What are we working on? a car/truck/van.
Oct 21, 2007 at 12:34 PM
APPLESAUCE
  • 5 POSTS
its a 97 bonneville 4 door sedan over 1k miles.
Oct 21, 2007 at 11:08 PM
Could be a rear drain tube that is clogged-up
Oct 22, 2007 at 10:17 AM
APPLESAUCE
  • 5 POSTS
[quote:1bc37cf75c="rasmataz"]Could be a rear drain tube that is clogged-up[/quote:1bc37cf75c]
is it possible to un-clog it myself?
Oct 22, 2007 at 1:27 PM
Find the drain tube and use a coat hanger and work it in.
Oct 22, 2007 at 1:30 PM
DCL427
I had a simular problem with my 99GP. Mine turned out to be the protective cover over the blower motor wheel. It's located under the cowl that covers the windshield wiper arms. Without the cover in place the openning was able to fill with rain water and leaked out the bottom of the Blower motor housing...In this case the water would be clean and clear like tap water...It something you may want to check...Dan
Nov 15, 2007 at 7:13 AM
