Mixture control solenoid
TCSURLES
  • PONTIAC BONNEVILLE
Make: Pontiac
Model: Bonneville 4 door
Year: 1984 built in Kansas City
Milage: 170,000
Engine: 3.8L (231 cid) 2bbl Dual Jet 210 A
The Mixture Control Solenoid continuously runs just as you turn the ignition switch on but do not crank the engine. This floods the engine. The 2 sec cutout does not engage and the 4 lbs oil pressure limit does not work either. Any ideas/remedies will be surely appreciated.
Wednesday, September 19th, 2007 AT 7:37 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 48,259 POSTS
Mixture solenoid can not flood the engine, try looking as the float level, as far as the oil pressure cut off not working, try unplugging the connector and see if the engine will not run, if not replace the oil pressure sender.
Wednesday, September 19th, 2007 AT 10:10 PM
