gas in the oil
CPOE
1988 pontice bonniville will not start gas is in the oil .i change oil it will run for little while, 8 cycle
Sep 5, 2007 at 2:21 PM
  • 75,988 POSTS
[quote:03cbe6a194="cpoe"]1988 pontice bonniville will not start gas is in the oil .i change oil it will run for little while, 8 cycle[/quote:03cbe6a194]
Could be the fuel pressure regulator and injector/s leaking and finding its way to the crankcase.
Sep 5, 2007 at 3:17 PM
COSTADELBOY
  • 26 POSTS
I don't Know your motor but this normally happens to engines with mechanical fuel pumps, the diaphram has a pin hole or rupture allowing the gas to pass thru and mix with oil. When it gets realy bad the pump stops working and the vehicle won't start
Sep 5, 2007 at 3:59 PM
