crankshaft pulley removal
DEVILS_DIVA76
i have a 1987 pontiac bonneville. thr crankshaft pulley { damper pulley i think it's called } needs to be replaced. i have tried everything and even baught a air compressor and air gun still i can't get the bolt out. I am not even sure which way it is supposed to turn , lol. can someone please help.
Oct 2, 2007 at 4:20 PM
  • 75,988 POSTS
Determine engine rotation
Posted at Sun Sep 30, 2007 6:19 pm
By rasmataz, Certified 2CarPros Master Technician
(346) Give Feedback | Votes: 41
You can use a breaker bar with the correct extension and socket 1/2 in drive ratchet slide it thru in a short piece of pipe-extend it then brace it properly on the ground or within the engine/suspension component.and crank the engine over using the key-this will break the center bolt loose.
Before you crank-disable the ignition coil so that it won't start.
_________________
2Car's Certified PAST Foreign/Domestic, Donations are very much appreciated to keep us in operation. Give GENEROUSLY!
Oct 2, 2007 at 4:49 PM
