2004 Pontiac Bonneville A/C Drain
STACEYBENNY
I have a 04 bonneville 42,000 miles v6. For a while i was having a foul odor when starting the a/c kinda went away and now when I turn my steering wheel to the left the blower starts to sputter and skweak. I also have a puddle of water on the passenger side floorboard. I checked for the sputtering on all functions(heat, defrost and vent) it does the same thing on all but only when I turn left as soon as I straighten the wheel it blows normal again? Help!
Aug 3, 2007 at 12:46 AM
CLY
  • 308 POSTS
Sounds like the drain for the a/c system maybe pluged and the blower motor maybe getting water on it. That would also be why the floor is wet. Check and make sure that the a/c drain is clear...
Cly
Aug 3, 2007 at 7:52 AM
Suggested Repair
Check and clear the A/C evaporator drain so backed-up water does not wet the blower motor or passenger floor.
Conversation Summary
The owner of a 2004 Pontiac Bonneville reported a past foul A/C odor, water on the passenger floor, and blower sputtering and squeaking when the steering wheel is turned left on all HVAC modes. The expert said a plugged A/C drain may be letting water reach the blower and recommended confirming that the drain is clear.
