2005 Pontiac Bonneville rear brake caliper
2005 PONTIAC BONNEVILLE
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
JUBENICK
I'm trying to replace the rear brake pads, and where there is normally a bolt on the top and bottom of the caliper, there is only a bolt on the bottom of the caliper. The top has a silver hub like cover, but there is no nut. How do I remove this to be able to remove the caliper to get the old pads off.
Thank you
Jul 14, 2008 at 10:59 AM
BOBBYTECH1
  • 49 POSTS
hey!! remove the bottom screw or bolt and lift the caliper up using the top bolt or pin as a pivot and slide the caliper off!! i hope it helps
Jul 14, 2008 at 11:04 AM
