2005 Pontiac Bonneville Burning Oil
2005 PONTIAC BONNEVILLE
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
TPATTERSON
Every 3000 miles the engine warning light comes on showing check oil level. It seems the car burns a quart every 3,000 miles. I do not see any leaks, drips on the ground and it does not smoke.
What can cause the car to burn a quart of oil every 3K miles?
Thx.
Tom
Mar 31, 2009 at 9:06 AM
DOCFIXIT
  • 18,828 POSTS
How often do you change oil and filter?
Apr 1, 2009 at 8:34 AM
TPATTERSON
Every 3000 to 4000 miles.
Thx
Apr 1, 2009 at 8:40 AM
DOCFIXIT
  • 18,828 POSTS
Might try replacing PCV valve if crankcase is not ventalated well oil can collect moisture and burn off.
Apr 1, 2009 at 9:30 AM
