2003 Pontiac Bonneville inner tie rod
2003 PONTIAC BONNEVILLE
LOREN CLEMENS
Suspension problem
2003 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
do I need special tools to replace the left inner tie rod, and do I need to remove the rack and pinion unit from the car to perform this repair?
Oct 28, 2008 at 12:23 PM
  • 110,194 POSTS
Hi:
There are no special tools needed and the rack doesn't need removed. However, you will need patience because it can be a tough job.
Let me know if you have any trouble.
Nov 7, 2008 at 10:19 PM
