2003 Pontiac Bonneville Battery Dead
2003 PONTIAC BONNEVILLE
84,000 MILES • 6 CYL • FWD • AUTOMATIC
DMTBONNEVILLE
My headlights on my auto do not turn off which is causing the battery to be drained. I have turned the delay mechanism off of the lights but they still do not go off. Any suggestions?
Jan 1, 2009 at 2:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like your switch has become faulty. Test for power with a meter at the headlight switch. If power is present while the switch is turned to off position, replace switch.
Hope this helps..
Thanks for using 2carpros.com!
Jan 1, 2009 at 3:19 PM
