2002 Pontiac Bonneville Windows and locks
2002 PONTIAC BONNEVILLE
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
PHIL1833
The passenger side window/door locks and two back windows/door locks don't work. Back windows went out first passenger then drivers side then the front passeneger window stop working now none of the door locks work except the drivers door.
Jan 22, 2010 at 9:18 AM
ERNEST CLARK
  • 1,730 POSTS
Your drivers side switch is the master switch for the entire vehicle. The wires that run through the door jam of the driver's side also run to the rest of the doors.
Some times these wires get broken or their insulation frays and develops a short circuit.
If you're handy with a test light, you could peel back the rubber boot that protects the wires in your driver door jam. Probe each wire that's connected to the master door/window switches for the other doors. You'll find that one or more of them have breaks in the wiring.
It's easy to fix once you find the bad wires.
If I've helped you, please vote for me, as I depend on this to pay my bills. Thanx, ernest.
Jan 24, 2010 at 9:02 AM
