2002 Pontiac Bonneville Rear Power Lock and Power Window Fa
2002 PONTIAC BONNEVILLE
72,000 MILES • 6 CYL • FWD • AUTOMATIC
CLIPGTO
I have a 2002 Bonneville SLE, and both rear power windows and door locks failed at the same time. Neither the front driver door switches or remote keyless will lock or unlock the rear doors. The rear windows do not move with either the front left switches or the switches in the individual doors. I know it is not the regulators as they were both just replaced, and whatever the problem, it is affecting both the locks and windows.
The rear door module fuse is good, and I had ordered a left rear module replacement on ebay, but it did not fix the problem.
Aug 27, 2009 at 12:42 PM
JDL
  • 16,098 POSTS
Did you check for voltage at the rear door module fuse circuit? The orange wire carries voltage to the door module.
Aug 31, 2009 at 1:40 AM
CLIPGTO
Yes - I checked the voltage at the orange wire on the module, and I have 12 volts.
Sep 17, 2009 at 2:25 PM
JDL
  • 16,098 POSTS
I'd have to check the circuits at the door module.
Sep 18, 2009 at 2:09 AM
CLIPGTO
I only checked the voltage at the orange wire where it plugs into the module itself. Should I be looking in another location
Sep 20, 2009 at 10:02 AM
JDL
  • 16,098 POSTS
Check the black wire for ground. Also at the individual window switch, dark green is hot for up position, brown wire is hot for down, black is ground.
Sep 21, 2009 at 1:05 AM
