2002 Pontiac Bonneville oil pressure gauge keeps dinging
2002 PONTIAC BONNEVILLE
91,500 MILES • 6 CYL • 2WD • AUTOMATIC
SHAWN0409
need to no is there an oil pressure sensor problem when check gauge light comes on while running car needle sways back and forth and is this easy to repair and also my stabilizing warning comes on sometimes and the car bouce left to right when hitting bumps ?
Jul 9, 2009 at 7:48 PM
ZEUS1198
[quote:2de5085f90="shawn0409"]Engine Mechanical problem
2002 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic 91500 miles
need to no is there an oil pressure sensor problem when check gauge light comes on while running car needle sways back and forth and is this easy to repair and also my stabilizing warning comes on sometimes and the car bouce left to right when hitting bumps ?[/quote:2de5085f90]
I am having the same problem on my 2001 SSEI, I am hoping it can be solved by replacing the oil pressure sending unit, because it seems like an easy fix if that is case.
Jul 31, 2009 at 4:01 PM
SARA
I am having the exact same issue. Oil gauge going crazy and the stablizing warning as well.
I just signed up for this. Where do you click to find the actual answer?
Jun 10, 2012 at 7:10 PM
