2002 Pontiac Bonneville oil pressure
2002 PONTIAC BONNEVILLE
88,000 MILES • 6 CYL • 2WD • AUTOMATIC
LASERDAN1
The weather just turned cold, below zero, I started my car at work sitting outside, now my pressure gage is maxed out. It drops to zero when the key is off, but goes to 120 and stays. Did I blow up the sensor? if so, where is it located?
Jan 20, 2008 at 12:45 AM
Check the actual oil pressure with an oil pressure tester-if its normal-check wiring-okay replace the oil pressure sending unit.
Jan 20, 2008 at 1:58 AM
