2002 Pontiac Bonneville mass air flow sensor
2002 PONTIAC BONNEVILLE
TRYINGTO
Electrical problem
2002 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic
I have a scanner that says their is a probleum with maf or vaf, I have had the screen blown with a cleaner, replaced the air and fuel filter, along with plugs, still have a jerking in the engine, any ideas
Sep 16, 2009 at 11:53 PM
  • 110,244 POSTS
Has the check engine light come back on? Have you checked fuel pump pressure? Any vacuum leaks?
Sep 23, 2009 at 3:38 AM
