2002 Pontiac Bonneville Blows cold only on Passenger side
2002 PONTIAC BONNEVILLE
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
JPL
The A/C only blows cold cold oout the two vents on the Passsenger side but blows warm out the drivers side two vents. the car does NOT have dual climate controls, only one. the same happens when you select defroster. (cold on pas/warm on driver)
May 2, 2010 at 1:00 AM
  • 110,244 POSTS
Have you checked the HVAC connections under the dash?
May 2, 2010 at 11:41 PM
