2002 Pontiac Bonneville blower motor
2002 PONTIAC BONNEVILLE
MACH1BOATS
Heater problem
2002 Pontiac Bonneville 6 cyl Front Wheel Drive Automatic
I am changing the blower motor (which is not working) and I have the glove box out and side panel off as my Chilton book tells me , but it does not give much detail as to unbolting it. I removed the screws on the underside of the blower that I could see, but it is not coming out. I could only see 4 screws. Am I missing more and if so, where and what do I need to do?
Oct 27, 2008 at 9:16 AM
  • 110,240 POSTS
Hi:
I believe there are 6 bolts holding it on. Are you sure the motor is bad? Did you check the blower motor resister and the switch?
Nov 7, 2008 at 2:21 PM
