2002 Pontiac Bonneville blower fan
2002 PONTIAC BONNEVILLE
100,000 MILES • 6 CYL • FWD • AUTOMATIC
FORDMANDJ
2002 Bonneville SE - heater blower fan runs intermittently
Is this a common issue? The fan seems to work as normal when it does come on the issue is it comes and goes. Is this a sign the motor is going bad or is there some sensor that controls the motor that needs replacing?
Dec 10, 2009 at 11:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the blower motor relay, it could be sticking causing failure of the blower motor intermittently.
Dec 10, 2009 at 11:02 AM
