2002 Pontiac Bonneville AC Question
2002 PONTIAC BONNEVILLE
87,000 MILES • 6 CYL • FWD • AUTOMATIC
NOTACARPERSON
  • 6 POSTS
The AC (and heater) in my Bonneville has been acting up for a while and I have decided it is time to get it resolved.
Description: The AC and heater do not work immediately upon turning them on. I can feel cold air (when the AC is on) coming out of the vent, but it is very weak even if it is turned to high. After a period of time, sometimes short sometimes much longer like 30-40 minutes, it will kick on and run as normal. Occasionally it seems like hitting a bump or accelerating quickly (getting on the interstate) will cause it to kick on, but this may have just been a coincidence as I know of times where hitting a bump and accelerating have had no effect. Also, turning off the AC after it has started working and turning it back on can sometime cause the issue again.
Any thoughts or suggestions are greatly appreciated.
Aug 17, 2009 at 3:24 AM
JMALECKI
  • 118 POSTS
Hello
it sounds like you may have a bad blower motor, when you have the problem again tap on the blower moter if it takes off and staarts working normal that is the problem.
John
Aug 19, 2009 at 12:41 PM
