2001 Pontiac Bonneville trouble codes
2001 PONTIAC BONNEVILLE
J101560
is there a way to use a jumper wire to check for trouble codes? if so what ports do you put the jumper wires in?
also, will disconecting the battery reset the warning litghts
Nov 20, 2009 at 2:07 AM
  • 110,240 POSTS
On the older vehicles there was a jumper. On yours, you need a scanner. If you disconnect the battery, it may or may not reset the computer.
Dec 16, 2009 at 1:13 AM
